How do I do this?
All  1  2-8
636.2 In reply to 636.1
> By the way, Michael, yes modifying the settings you told me last night
> before importing IGS files, no problems.
Hi Rudy, that's good - you'll probably need to use those modified settings to work with those types of denser relief surfaces until I can fix this problem. It's probably a good idea even on a higher memory machine since the really dense display mesh will generally slow things down and take longer to draw in addition to taking up a bunch of memory.
About curving the relief around the band - MoI doesn't have anything that will perform that function. You'll need to use Rhino 4.0 for that type of warping procedure, they have a new tool in version 4 called "FlowAlongSrf" that will do that type of processing.
636.3 In reply to 636.2
Thanks Michael,
I appreciate all of your valuable suggestions .
Rudy
636.4 In reply to 636.1
OK, here combi
(Zsurf.....Basesurf......Zylinder) and (MOI....Array.....Command.....Zylinder.....HideCommand)
For viewing geometry open the "BassRelief.3dm" and use HideCommnad
for Zsurf read
http://www.moi3d.com/forum/messages.php?webtag=MOI&msg=602.1
BestReg`s EDDI
EDITED: 4 Jul 2007 by EDDI
636.5 In reply to 636.4
Wow, very cool! That avoids the problem of needing to bend it in MoI by using a Cylinder base surface in ZSurf for creating the surface.
Nice result!
636.6 In reply to 636.5
Eddi,
yes, I have done my relief in Zsurf.....
I am going to study your procedure (I am going to print it out as well).....Thank you a lot !!
Best,
Rudy
636.7 In reply to 636.6
Halo to everything,
Yeep, Zsurf is a good tool for bassrelief and bendcommand.
I also thinks, for bend is still too early, very important it is edge_select_command (edgeloop,edgering,edge+ -),
without edgecommand, modelling is expenditure-braked.
Rudi, in the picture sees combination between Blend+HideCommand.
You must turn writings in Zsurf :
Zsurf...Open...Cancel...Cancel...Font (Enter text)...RMB (Rotate Activ)...LMB (Rotate)...MakeBitmap
BestReg`s EDDI
EDITED: 3 Jun 2007 by EDDI
636.8 In reply to 636.7
Dear Eddi,
thank you!
You made my day.
Thank you to Michael as well, he has always taken the time answering my strupid questions....
I owe you guys.
Rudy
Show messages: All  1  2-8
