Construction lines
All  1-2  3-4
6356.3 In reply to 6356.1
Normally you don't need menu for Helper Lines!
Just Click & Drag without release, then relase! :)
After the first call of a function, before the first click of a function, after the first click of a function, before the last click of a function!
6356.4 In reply to 6356.1
Hi al,
> Hello, just a quick (and hopefully simple) question. I'm trying to set up Moi for use with a
> tablet, and, being naturally cack-handed, I'm struggling to hit the small marker for the
> construction lines pop-up menu. Is there a command that I could map to a hotkey?
Sorry right now there's no way for a script to access that particular thing. But you could increase the size of the marker by increasing the size of PNG image file named MenuLauncherTag.png located in the \ui sub-folder. If you bring that image into a bitmap editor program and scale it up, it should also increase the targeting area of it as well.
@ Max,
> Oh yeah, would help. And what is the command name for the CPlane? I'd like to bind it
Check out here for some CPlane scripts you can use:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2168.17
Show messages: All  1-2  3-4
