Another newbie
All  1-6  7-11
6348.7 In reply to 6348.5
A full scripts library will be nice indeed, but right now I only wanted those more "standard" commands. These will suffice!
I think I've ironed out most of my initial gripes with MoI, let the modeling begin :)
Thanks a lot!
6348.8 In reply to 6348.7
Hi Duarte, also if you've previously spent a lot of time doing sub-d modeling in Blender it can sometimes take a while to get used to the very different strategy that you use with NURBS modeling. Basically with NURBS modeling you want to use booleans as a primary way of getting things done, and also try to form most of your model with 2D curves, some 2D curves used for generating things and some for cutting things.
So under regular circumstances a lot of the 3D edges in your final model will be a result of a cutting operation or something like that, rather than all the 3D edges drawn in by hand directly.
One kind of key thing is when you have something that ends in an irregular edge, often times you want to build a more simple initially extended shape and then cut off the end of that piece rather than trying to directly construct surfaces right to the irregular edge itself.
Check out here for some links to discussions and general tips for people who are coming from a sub-d / poly modeling background:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
6348.9 In reply to 6348.8
Although I am a sporadic Blender user, mostly has a hobby of for personal freelance work, I use 3DsMax much more often, because that's what we (are forced to) use at work.
I am an architect however, so my background and first contact with CAD and 3D modeling actually came from AutoCAD, so I am quite accustomed to Boolean operations and Solid modeling, my ascension to full NURBS should be a bit easier eheh.
I actually have more difficulties in getting into full Mesh modeling and Blender in general, because in 3Dsmax I use almost exclusively curve based modeling (with extrude/sweep and other modifiers) all the time, and I've had a bad time doing that in Blender because it's curve editing tools are quite messy and even worse than those of 3DSmax
Thanks for the tips though, I'll be sure to take a look at those threads, a reminder is always helpful. :)
6348.10 In reply to 6348.9
Hi Duarte, yes with your background you're probably going to feel pretty comfortable with booleans and 2D curve driven stuff right off the bat.
It tends to be a bigger adjustment for people coming from a heavy sub-d modeling background since they're very used to a kind of sculpting-like workflow of pushing things around in 3D rather than curve-driven stuff.
Doing the UI translation probably gave you a pretty good overall introduction to MoI as well! :)
6348.11 In reply to 6348.10
You are most welcome for the translation, and yes indeed, having done that makes me feel like I already know all the commands available and how they work (the one with an UI at least), especially because I had to test many of them to ensure I totally grasped what they did and guaranty a good translation. Ironically, having translated all the UI, I hate using software in any language other then English, and never use Portuguese translations. I'll be forcing myself to use it in MoI for a while though, just to maximize the chances of catching any translation errors or see if I can improve the wording anywhere.
I do little AutoCAD modeling these days, as for Archviz 3Ds Max cover most of the day-to-day modeling needs, but I have not forgotten how it works some as times it's still needed and I actually enjoyed the workflow. I also just love and use 2D vector drawing software like Inkscape which gives a good background for how Bezier handles work, albeit 2D ones, which will be handy to deal with NURBS objects.
Like Metin mentioned, MoI also seems to deal very well with this kind of 2D drawing and exporting to PDF is great to later import in Inkscape and do some final post-processing and fine tuning.
I'll try and use MoI mostly for my long standing desire to do Science Fiction Concept modeling (spaceships vehicles robots etc.) as a hobby and see how it goes. The skills will definitely come in handy for any occasional more complex architecture models that might come up. Once again the vector PDF export will be excellent to obtain rigorous plans/elevations of constructions.
Show messages: All  1-6  7-11
