Working with files from Alias...?
All  1-3  4-18
6341.4 In reply to 6341.3
Hi sneather, IGES does have the concept of a "Level" which is basically the same as a layer. I don't know for sure that Alias writes that information out to the IGES file but if it does then the layer grouping should come through too with IGES format. You'll lose the specific name, they'll be named things like "Level 1", "Level 2", etc... in MoI because an IGES level is just a number and not a text name though.
But it's also possible that the way trim curves work in IGES will more closely match how Alias structures them itself so if you're running into problems with things trimmed incorrectly that may possibly be lessened in this particular circumstance using IGES.
6341.5 In reply to 6341.3
But also, if the model data is not already set up to have surfaces that touch edge to edge in a clean manner, then it's just not ready to be built directly into a solid (by a push button method) no matter what format you use...
6341.6 In reply to 6341.4
Okay. Thanks. On Monday, I'll ask the Alias designer to try out some IGES exports.
I may have to try that for the more complicated sheet issues, then use STEP for the simpler parts.
6341.7 In reply to 6341.5
Regarding the actual state of the model, itself. Yes, I've already had the designer go back and clean up some of the more obvious surface issues. Most of those (once joined in MOI) seem to be free of naked edges. But again, oddly, some of those seemingly clean edges still won't hold a bevel. But per your previous post, I'll see whether IGES exports might help at all.
Thanks!
6341.8 In reply to 6341.7
Hi sneather,
I'd need to see the actual model in order to try and give you any information on this part.
6341.9
Update:
I had the Alias designer try sending me an .igs file. I couldn't open it in either the current version of MOI, nor the v3 Beta I have. No warnings, simply nothing imports. Just to make sure that the file wasn't corrupted, I tried Rhino, and it came in perfectly.
Any ideas? Are the IGES issues with MOI? Or are there export steps needed to write the correct file from Alias?
6341.10 In reply to 6341.9
Hi sneather, I'm not aware of any particular issues with MoI's IGES importer. I would need to see the particular IGES file to be able to give you any good information about what's going on there. If you are able to, please send it to me at moi@moi3d.com
There are a few different ways that it is possible to store things in IGES files, I guess that probably the method used for that file is not supported by MoI's IGES reader.
If they have some options they can change at export time, ask them to set it to export "Type 144" trimmed surfaces and see if that works any better.
6341.11
I'll have to see what I can do about assembling the IGES file. But even at best, it's still (obviously) a much bigger pain to work with - as compared to STEP, because the lack of naming structure and the sheer number of pieces to re-join.
In the meanwhile, I was at least able to get the Alias designer to send me a comprehensive screen grab of the potential export settings for STEP files, from Alias. Do any of these stand out as critical in regards to how MOI might best prefer?
Thanks!
6341.12 In reply to 6341.11
Hi sneather, probably you'd want Trim curves with the "Model space" setting.
I'm not 100% sure what some of those other settings mean exactly like what in particular Alias means by a "hybrid model", that's some kind of terminology specific to Alias and not particularly a general STEP specific thing as far as I know.
Protocol type AP203 versus AP214 - either should work ok, but the 203 type contains only geometry and not any names or color information, that's stuff that has been added in by the 214 variant.
6341.13 In reply to 6341.12
Great. Thank you for taking the time to review these screen grabs, Michael.
I'll ask the designer to try out what you recommended, and see whether any of that helps (at least a little).
He did ask me whether I could handle WIRE format, as supposedly that's rather native for Alias. But I've never seen that as an import function for any software app I use. That could be some of the trouble, in that Alias really does work within its own proprietary world, and trying to get functionality with divergent apps might not be as easy, compared with other CAD systems.
6341.14 In reply to 6341.13
Here you go sneather:
http://www.autodesk.com/techpubs/aliasstudio/2010/index.html?url=WS1a9193826455f5ff-54f556ca1166ac9ee9e-7a77.htm,topicNumber=d0e178529
Link this to your designer.
If the model is a "solid" (as in MoI solid) the he will use the G5brep solid option.
So there are some other options, but they really depend on what's being exported. The designer will know whether it's "surfaces" or "solids" and whatnot. You'll want to avoid wires. You would have to rebuild all the surfaces, and would loose what Alias is doing with regard to surface continuity and such.......
The hybrid model thing is exporting out "all things alias", and can cause issues.
6341.15 In reply to 6341.13
Hi sneather,
Yeah it's the native file format for Alias. It's not very often supported by other software, I don't think that it's a publicly documented file format.
I seem to vaguely remember something with PolyTrans being able to do it:
http://www.okino.com/tutorials/gplugs_tutorial.htm
It's more likely that IGES or STEP would be the way to go.
6341.16 In reply to 6341.14
Thank you!
6341.17 In reply to 6341.15
Thanks, Michael.
6341.18 In reply to 6341.15
ALso, just as more added info, it may be a communication error with regard to "Wires". meaning, not necessarily the "dot wire format", but wires as in edges. Alias' export can be solids, surfaces or wires, with several options for each (the hybrid is all of those things and options) and, Alias kind of does all it's surfacing WITH wires. I don't think those would work for export though, because alias will be carrying all sorts of surface continuity information along with the wires, so MoI running sweep on 4 closed edges from alias will not produce the same surface with "edge directions" regarding tangencies.
lol
Show messages: All  1-3  4-18
