Working with files from Alias...?
All  1-12  13-18
6341.13 In reply to 6341.12
Great. Thank you for taking the time to review these screen grabs, Michael.
I'll ask the designer to try out what you recommended, and see whether any of that helps (at least a little).
He did ask me whether I could handle WIRE format, as supposedly that's rather native for Alias. But I've never seen that as an import function for any software app I use. That could be some of the trouble, in that Alias really does work within its own proprietary world, and trying to get functionality with divergent apps might not be as easy, compared with other CAD systems.
6341.14 In reply to 6341.13
Here you go sneather:
http://www.autodesk.com/techpubs/aliasstudio/2010/index.html?url=WS1a9193826455f5ff-54f556ca1166ac9ee9e-7a77.htm,topicNumber=d0e178529
Link this to your designer.
If the model is a "solid" (as in MoI solid) the he will use the G5brep solid option.
So there are some other options, but they really depend on what's being exported. The designer will know whether it's "surfaces" or "solids" and whatnot. You'll want to avoid wires. You would have to rebuild all the surfaces, and would loose what Alias is doing with regard to surface continuity and such.......
The hybrid model thing is exporting out "all things alias", and can cause issues.
6341.15 In reply to 6341.13
Hi sneather,
Yeah it's the native file format for Alias. It's not very often supported by other software, I don't think that it's a publicly documented file format.
I seem to vaguely remember something with PolyTrans being able to do it:
http://www.okino.com/tutorials/gplugs_tutorial.htm
It's more likely that IGES or STEP would be the way to go.
6341.16 In reply to 6341.14
Thank you!
6341.17 In reply to 6341.15
Thanks, Michael.
6341.18 In reply to 6341.15
ALso, just as more added info, it may be a communication error with regard to "Wires". meaning, not necessarily the "dot wire format", but wires as in edges. Alias' export can be solids, surfaces or wires, with several options for each (the hybrid is all of those things and options) and, Alias kind of does all it's surfacing WITH wires. I don't think those would work for export though, because alias will be carrying all sorts of surface continuity information along with the wires, so MoI running sweep on 4 closed edges from alias will not produce the same surface with "edge directions" regarding tangencies.
lol
Show messages: All  1-12  13-18
