Just discovered MoI yesterday
 1-7  8-27  28-33
6338.8
Thanks. I am sure I will enjoy MoI - and the forum.
I have printed out the manual and yesterday, I started working my way through all the different functions to get a feel for how they are to work with in practice. I think I'm roughly halfway through by now, and I keep getting more and more impressed (rather than more confused as one might do with certain other programs). I think I already have some ideas for future version improvements too, though, so I'll get back to that when I know all the current ones well enough.
6338.9 In reply to 6338.7
By the way, I've already found your tutorials on YouTube. I've been through two of them so far. I think they are very good.
6338.10
I am still working my way through the manual, but I do find MoI very easy to use, and while I was trying out the blending function, I just suddenly and accidentally had something that looked like in-ear headphones, so I just added a tiny speaker and a silicon earbud. I am fascinated by how easy this was to make, practically making itself.
I've not laid them out properly or done anything beyond default lighting, but I thought I'd share a small rendering anyway.
I also included a vase I revolved from a curve yesterday.
By the way, I was trying to fillet the join at the base of the headphones where it goes from an oval shape to a round shape (which I made with a blend), but I didn't seem able to do that. Not sure what I am doing wrong there, so any tips on how to make it work are appreciated.
6338.11 In reply to 6338.10
"""""""By the way, I was trying to fillet the join at the base of the headphones where it goes from an oval shape to a round shape (which I made with a blend), but I didn't seem able to do that. Not sure what I am doing wrong there, so any tips on how to make it work are appreciated.""""""
a "Blend" would not have any joins that would be/need a fillet. The connections would be tangent. That looks like it was made with a "loft" which just made a straight shot from the oval to the circle, but leaves a hard edge at the oval connection. The fillet there will be tricky and probably have one side look creased, but the other side be more tangent (no fillet).
So you CAN run blend there, to get a smooth transition. First, capture the ending circle by doing a drill down selection (click the object, then do a second click on edge (circle) and copy and paste it. Then do a drill down selection on the surface that goes from the oval to the circle and delete it (You now have an open edge on the oval side) Do and extrude of the circle with no caps. Now you can blend the edge of the oval and the edge of the circle. Delete the extruded circle surface and cap the end of the blend and join the surfaces.
It helps with stuff like this if you provide a 3dm file of the model to look at exactly whats going on....
6338.12 In reply to 6338.11
Ah. I probably used loft. I'll try your suggestion, BurrMan. Thanks.
6338.13 In reply to 6338.12
That worked a charm. Thanks a lot.
6338.14
Today's exercise I set for myself: to construct a regular icosahedron. With MoI's ease of use, this didn't take very long. Time from starting to look at the Wikipedia entry for Isocahedron to get some construction ideas until posting it here: 30 minutes.
Cuty!
6338.16 In reply to 6338.14
Hi Hakon, you may also be interested in some of these previous discussions on polyhedra construction:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.46
http://moi3d.com/forum/index.php?webtag=MOI&msg=2153.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3798.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=2275.1
There's also a collection of various models in 3DM format here:
http://www.rhino3d.nl/pythposter/pyth3dm-eng.html
6338.17
Thanks, Michael,
I did a dodecahedron after the icosahedron, so I figured that one out on my own after a quick Wikipedia lookup. It took a little bit longer, though.
I'm not really interested in just the finished shapes as from your last link, at least not right now when I am trying to learn how to use MoI, working with construction lines, setting coordinate, distance or angle constraints, and trying to think more in 3D. It might be useful knowing where to find them some day, though, so thanks for the link.
I have moved on from regular polyhedra to figuring out how to construct gems from cutting charts. That is a bit more difficult, but I think I am on the right track. First time I've done anything very trigonometrical since school, but MoI's construction lines are extremely helpful and powerful. So is rail revolve for quickly constructing cutting facets.
Seems I might get MoI for Christmas from my wife, so I can just keep going once my 30-day trial is over.
6338.18
Yesterday evening's exercise is completed, with a brilliant cut diamond exactly to the specifications in the cutting chart. It took a few hours, but I now I could do a new one a lot quicker, having a bit of a routine for it.
I think I'll probably do one more just to see how my routine works on another chart before moving on to something else.
6338.19 In reply to 6338.18
Do you have a link to the gem charts?
(I did an asschur cut a while back.)
6338.20 In reply to 6338.19
Hello, Brian,
I found it on http://www.facetdiagrams.org/
Here is the specific one I used: http://www.facetdiagrams.org/database/files/pc01006.html
6338.21
An illusion star cut. Far more complex and more challenging than a brilliant as I had to rethink my method once the cut bases weren't all regular polygons anymore. But, with what I've learnt from doing that today, I can now do any gem with exact precision based on a cutting chart, so it's been a useful exercise.
For this one, I actually started with an extruded 48 facet base and almost literally cut the diamond face by face in MoI according to the cutting chart. I can't see any other way of doing it with the same precision. One could probably eyeball it and make something that looked nice much faster, but angles would be wrong, and so realistic ray tracing would reveal imperfections in the cut.
This one doesn't look as good in a static image. I guess it's one of those cuts that really only come into their own once the diamond is subject to constant movement.
6338.22 In reply to 6338.21
Cool!
Have you some blueprints of these sort of things ?
6338.23 In reply to 6338.22
Thanks, Pilou,
I use the cutting charts as found on http://www.facetdiagrams.org/
I might make a tutorial one day soon describing how to cut the gems in MoI with absolute precision. It's not the most straightforward thing to do.
6338.24 In reply to 6338.23
Thanks for the info!
6338.25
Moi is perfect for precise things like this. There is an input box at the bottom of the screen where you can input angels and other things for precise distances, angles, etc.
6338.26 In reply to 6338.23
"""""I might make a tutorial one day soon describing how to cut the gems in MoI with absolute precision.""""""""""""""""""
Me likey.... Please. :)
6338.27 In reply to 6338.26
BurrMan, until I do make a tutorial, I did find someone else online who use a method very similar to the one I devised. His method is described here: http://www.3dlapidary.com/HTML/Facets.htm and it should work well in any 3D program.
The website also has a lot of finished gem files, though some conversion might be necessary. There are Rhino files there, which supposedly should work in MoI, but when I tried opening them, nothing showed up on my screen. Not sure if there's a version mismatch as some of these seem rather old. I have started converting some of the .obj and .dxf files, though. As much fun as it is to make these oneself, it is time consuming (though, that is perhaps part of the fun too as long as you consider it a hobby), and it's nice to have a collection of finished gemstones on hand, too, for other jewellery work.
Show messages:  1-7  8-27  28-33
