Just discovered MoI yesterday
 1-18  19-33
6338.19 In reply to 6338.18
Do you have a link to the gem charts?
(I did an asschur cut a while back.)
6338.20 In reply to 6338.19
Hello, Brian,
I found it on http://www.facetdiagrams.org/
Here is the specific one I used: http://www.facetdiagrams.org/database/files/pc01006.html
6338.21
An illusion star cut. Far more complex and more challenging than a brilliant as I had to rethink my method once the cut bases weren't all regular polygons anymore. But, with what I've learnt from doing that today, I can now do any gem with exact precision based on a cutting chart, so it's been a useful exercise.
For this one, I actually started with an extruded 48 facet base and almost literally cut the diamond face by face in MoI according to the cutting chart. I can't see any other way of doing it with the same precision. One could probably eyeball it and make something that looked nice much faster, but angles would be wrong, and so realistic ray tracing would reveal imperfections in the cut.
This one doesn't look as good in a static image. I guess it's one of those cuts that really only come into their own once the diamond is subject to constant movement.
6338.22 In reply to 6338.21
Cool!
Have you some blueprints of these sort of things ?
6338.23 In reply to 6338.22
Thanks, Pilou,
I use the cutting charts as found on http://www.facetdiagrams.org/
I might make a tutorial one day soon describing how to cut the gems in MoI with absolute precision. It's not the most straightforward thing to do.
6338.24 In reply to 6338.23
Thanks for the info!
6338.25
Moi is perfect for precise things like this. There is an input box at the bottom of the screen where you can input angels and other things for precise distances, angles, etc.
6338.26 In reply to 6338.23
"""""I might make a tutorial one day soon describing how to cut the gems in MoI with absolute precision.""""""""""""""""""
Me likey.... Please. :)
6338.27 In reply to 6338.26
BurrMan, until I do make a tutorial, I did find someone else online who use a method very similar to the one I devised. His method is described here: http://www.3dlapidary.com/HTML/Facets.htm and it should work well in any 3D program.
The website also has a lot of finished gem files, though some conversion might be necessary. There are Rhino files there, which supposedly should work in MoI, but when I tried opening them, nothing showed up on my screen. Not sure if there's a version mismatch as some of these seem rather old. I have started converting some of the .obj and .dxf files, though. As much fun as it is to make these oneself, it is time consuming (though, that is perhaps part of the fun too as long as you consider it a hobby), and it's nice to have a collection of finished gemstones on hand, too, for other jewellery work.
Totally ignoramus: as I see all lines are straigt lines does it possible to have curves in a daimond ?
6338.29 In reply to 6338.28
There is no mechanical reason not to have curved lines in diamonds - especially virtual ones. I guess the facet cuts have developed over time to make sure that all the light coming from above the gem is reflected back up inside the gem to get the most interesting play of light when you look at it. Curved shapes would have a different effect, and there's nothing stopping you from experimenting with that to see what happens if you have access to a realistic renderer where you can adjust refractive indices and where you get realistic caustic effects.
6338.30
Metropolis Light Transport is what I used.
...and you have to know something about the IoR (Incident of Refraction & Reflection) of the gem material.
The type of spot lighting is also crucial.
FYI - shayno posted some gemstone 3DM files a while back here:
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=4423.4
Ed
A B Carter created three Rhino tutorials on how to create the gems, and explained the cutting charts.
The tutorials no longer seem to be on the Renderosity site.
EDITED: 11 Dec 2013 by BEMFARMER
6338.33
A day did pass without any MoI experiments as I also had to do some work.
Yesterday evening, I set myself a new non-gemstone challenge of making a fork, and although I overdid the curvature of it, I think it looks fine. Starting with the outline of my favourite silverware set I have at home, I did some extrusions, divisions, curve projections, as well as a sweep to make the subtle bulge on top of the handle. All good practice in using the basic toolset of MoI.
As the fork looked a bit lonely on its own, I threw in a revolved wine glass with rose-like contents I made a few days ago.
Show messages:  1-18  19-33
