Erasing Curves generator
All  1-3  4-10
6316.4
weird. it's supposed to work. can you try again plz? maybe I pasted it incomplete.
6316.5 In reply to 6316.4
Now that works but...
here i redraw a sphere for the image!
...and it's for general and not only for selected objects !
And if I hide before the slice with your plugin, that return after the slice!
EDITED: 29 Nov 2013 by PILOU
6316.6 In reply to 6316.5
1. Seam edges can't be deleted, you can only hide it. because it's the curve which forms the sphere.
2. Your sliced spheres are sliced vertically. Short lines are not seam edges anymore, they're regular lines because resulting pieces are calculated differently than the sphere thus this script is not working.
3. if you sliced them horizontally, script would work.
4. yes they return after slice because script hides it only visually. :(
5. yes this script affects whole scene. :(
- Evren
6316.7 In reply to 6316.6
Thx for the efforts!
6316.8
If you slice your sphere like this and run script afterwards, it will hide seam edges
- Evren
6316.9 In reply to 6316.8
I had no chance because that is working 3 / 4 by step of 90° :)
yes or like this! ;)
But that is working only for simple objects ;)
I can also select one by one and hide them! ;)
Thx for the research! :)
Flow on a sphere
Show messages: All  1-3  4-10
