Zebra Stripes
All  1-2  3-7
6301.3 In reply to 6301.2
> Is this a zebra stripe showing surface continuity levels?
In looks like it is in some areas, but you're also getting a lot of additional artifacts that are just from a low triangulation density as well. You'll want something like this to be very finely tessellated so that triangulation artifacts will be minimized as much as possible.
> Is there anyway to export bip files from MoI? Cannot find anydetailed description of the bip file format.
Not any way that I know of - as far as I can tell the .bip file format is not publicly documented.
> I have is the Alibre associated version, which only permits bip import.
I guess it is intentionally limited to a private undocumented file format so that you can only use it with Alibre. I think the regular non-limited version supports a lot of various other file formats and not only .bip .
6301.4 In reply to 6301.3
I think you need something that maps to a sphere better
What is a bip file?
Because in 3dsmax that is the norm of a file animation! :)
6301.6 In reply to 6301.5
> What is a bip file?
I think it's the native data format for the KeyShot renderer, containing mesh data, materials, lights, stuff like that.
6301.7
Keyshot can import step files. I haven't done any critical comparison whether MoI's conversion is better or faster than KeyShot's, though, but the latter seems fine, and it could save a bit of storage space too, all depending on complexity, of course.
Show messages: All  1-2  3-7
