Zebra Stripes
All  1  2-7
6301.2 In reply to 6301.1
Just for fun:
Here is a try at zebra stripe in Keyshot, of a MoI Model, seeing as how a cylindrical black and white light source is needed.
The bip file was via Alibre, as the Keyshot 3.x I have is the Alibre associated version, which only permits bip import.
The striped zebra.hdr file is just a renamed PNG file created in MoI, which is loaded into the Keyshot environment.
Is this a zebra stripe showing surface continuity levels?
Is there anyway to export bip files from MoI? Cannot find anydetailed description of the bip file format. It appears that
the Keyshot company makes plugins for other cad programs, for example Sketchup...
EDITED: 2 Apr 2015 by BEMFARMER
6301.3 In reply to 6301.2
In looks like it is in some areas, but you're also getting a lot of additional artifacts that are just from a low triangulation density as well. You'll want something like this to be very finely tessellated so that triangulation artifacts will be minimized as much as possible.
Not any way that I know of - as far as I can tell the .bip file format is not publicly documented.
I guess it is intentionally limited to a private undocumented file format so that you can only use it with Alibre. I think the regular non-limited version supports a lot of various other file formats and not only .bip .
6301.4 In reply to 6301.3
I think you need something that maps to a sphere better
What is a bip file?
Because in 3dsmax that is the norm of a file animation! :)
6301.6 In reply to 6301.5
> What is a bip file?
I think it's the native data format for the KeyShot renderer, containing mesh data, materials, lights, stuff like that.
6301.7
Keyshot can import step files. I haven't done any critical comparison whether MoI's conversion is better or faster than KeyShot's, though, but the latter seems fine, and it could save a bit of storage space too, all depending on complexity, of course.
Show messages: All  1  2-7
