MoI alternative for G2/G3 Fillets?
 1-12  13-22
6291.13 In reply to 6291.12
Hi Tom, you only need G2 for there to be visual continuity with reflections, G3 is more for bragging rights than anything you can actually see on the geometry.
6291.14 In reply to 6291.13
hehehe - okay, I take your word for it.
I usually use G3 in MoI when it works since I like the created profile - looks more natural or organic to me, similar to what SDS create, a certain kind of flow. Most of the time NURBS look too dead to me.
Cheers,
Tom
6291.15 In reply to 6291.14
Hi Tom, yeah if you're trying to make organic looking forms, usually sub-d modeling is a better fit for that style of stuff than NURBS modeling.
NURBS modeling is good for shapes that are well defined by 2D profile curves.
6291.16 In reply to 6291.12
""""""""""Every good Catmull Clark Subdivision Surface implementation with Edge Weighting gives you perfect visual continuity in reflections.
The mushyness is countered by the edge-weighting. """"""""""
Catmull clark is "trying" to give you C2, though it can still result in C1 at extraordinary vertices. It does this by melting everything down to try that average. Repeated subs can get close. The "perfect VISUAL curvature" result just means you "cant see the difference".
I was thrown by the request being "G3", or even "G2". There's is a difference.
"""""""""Since I come from the polygon-world originally, I'm always amazed how much effort and money are needed to get something similar in NURBS"""""""""
That's because the NURBS are actually perfect, and "DO" represent that. It's much easier to kindof "average everything down" to be somewhat close........
But like Michael points out, YOU cant really see the difference.
But there is a need in very specialized situations, where those values cant just be "moved around"........
6291.17
Well, since it seems that there's no G2 Fillets in any affordable software either, it's moot anyway. ;-)
And I have little influence on what my customers choose to do their work in. ;-)
Let's leave it at that.
Cheers,
Tom
6291.18 In reply to 6291.17
"""""""""Well, since it seems that there's no G2 Fillets in any affordable software either, it's moot anyway. """"""""""""""
Well, MoI does G2 fillets. Also G3 fillets as well.
""""""""""It's really too bad that on these models, imported from Catia as Step, I can't even fillet a single trivial edge, no matter what mode in MoI."""""""
But why?
Can you produce "ANY" example that doesn't work, that is not under NDA? I mean, a "single trivial edge" is kindof a broad, general statement.
6291.19 In reply to 6291.18
Burr, let it rest, it's okay.
6291.20 In reply to 6291.19
Wow. Ok Tom.
6291.21
Darn! I wanted to see these 'unfilletable' edges too, oh well I guess we'll just stick with edges that do fillet.
6291.22 In reply to 6291.20
Just to add some follow up on this:
Catia is unable to fillet those models as well, neither me nor my customer really understand why, but before we dive into endless debugging sessions, we decided that I'll rebuild the models for now as SDS objects - and he will look into MoI/Rhino for future construction. :-)
I only need the fillets for visualisation and rendering, so the results from SDS are just fine, therefore I didn't want to go into a loop discussion ;-)
Sorry if I came over defensive.
Thank you all very much for the input!
Cheers,
Tom
Show messages:  1-12  13-22
