Default ini file
All  1-2  3-11
6288.3 In reply to 6288.2
The release notes are being worked on now. Watch for a thread to start regarding the "November beta release".
Whats new? See this thread:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6201.1
There will be a couple other things we'll have to wait for the notes to specify.
6288.4 In reply to 6288.1
Hi Burr,
> The default ini file in the nov. beta comes in with several of the sections stripped out?
> Maybe they are created at runtime when first used? I just wanted to get that out
> there while you are finishing things up....
Are you talking about the new settings for hidden line removal? Yeah those will get created on demand when it's first used.
Is that causing a problem?
6288.5 In reply to 6288.4
Hi Michael, no, my default ini didn't have all the lwo/iges/mesh export type of settings. There were quite a few missing I hadn't noticed before as missing when I do the merge with the old and new.
There is no problem for me with it. I just wanted to point it out in case there was an oversight.....
6288.6 In reply to 6288.5
Hi Burr,
Yeah that should have been the case for a long time now, probably since v1... The settings for OBJ, IGES, and LWO export are all kind of grouped together and handled by one internal settings object, and the whole group of those settings will get initialized the first time any of them are used.
It's ok that they're missing, once anything that wants to use them asks for them, that's when the default values will be created and added in to the moi.ini at that time. The whole set of OBJ, IGES, and LWO settings will get added to the moi.ini file once any one of those export types have been done.
6288.7 In reply to 6288.6
Got it... I'll wait for the release thread for anything else...... :)
I've got some good results with the new exporter!
6288.8 In reply to 6288.7
Hi Burr,
Anything you can show?
6288.9 In reply to 6288.7
Hi Burr, also, re:
I may wait for about one more day before getting that assembled, just to give myself a little window of time to roll out a new version if there's any rapid fire severe bug fix needed.
6288.10 In reply to 6288.8
Sure! Nothing as a final setup yet. Just some initial exports. The image is the re-import of the pdf back into MoI!
EDITED: 27 Feb 2020 by BURRMAN
6288.11 In reply to 6288.10
Wow looks great Burr!
Show messages: All  1-2  3-11
