Separated Tabs in Side Pane
All  1  2-15
6278.2
Hi milkywaif,
Thanks for the sidepane. Much better now as i'm also on an 27inch display.
Still wasting a bit of space on the top, somehow the 1st Tool - Draw curve - leaves some empty space whatever is the UI size. Strange.
Wish i could separate the Tools from the viewports, to place it on an 2nd monitor.
Like a lot of your UI style, quite elegant. Care to share?
Carlos
6278.3 In reply to 6278.2
""""""""""Still wasting a bit of space on the top, somehow the 1st Tool - Draw curve - leaves some empty space whatever is the UI size. Strange.""""""""""""
Thats the command and object properties area. Run a command or select an object to see it.
If that area were to not be there during viewing, and then "pop in" when needed, the entire toolbar would be jumping up and down all the time.
6278.4
Hi Guilherme,
I'm glad you liked it.
I think top space is like BurrMan said, reserved for tool settings and object properties. At least all tabs are ungrouped and visible now :)
Of course. I'm sharing my complete ui folder as zip because replacing moi.css is not enough for sharp viewport corners. There are some edited png files (it's been a while, I forgot which they are). I edited them because I believe that's the only way to get rid of those ugly blue tinted, rounded viewport corners :p
6278.5
Hi BurMan,,
I understand, it doesn-t make sense the tools jumping all the time.
Thanks..
Carlos
6278.6
Hi Milkywaif,
Thanks, i-ll give it a try and hope not brake Moi : )
Carlos
6278.7
By the way this is what my MoI interface looks like in fullscreen
6278.8 In reply to 6278.6
Guilherme,
Just backup your ui folder somewhere to be safe :)
6278.9
Hi milkywaif,
Yes, will do that for sure. Thanks.
Stay some free space! :)
6278.11
Hi milkywaif,
It worked. Nice, much better. I like.
Thanks a lot.
Carlos
6278.12
Hi milkywaif
Thanks for the UI.. have been thinking about getting a 27" screen, currently running a 22" and 19" on my Mac mini.
Cheers, stephen
6278.13 In reply to 6278.12
Great !!! Didnt get the will to do it myself :O)
Thanks MILKYWAIF
6278.14 In reply to 6278.4
Great!
Very convenient.
6278.15
A little bonus: Nsided icon
I didn't spend too much time with it because original icon will be out when v3 final comes out.
Enjoy.
Show messages: All  1  2-15
