Tapering and Bending
 1-9  10-29  30-32
6277.10 In reply to 6277.9
"""""""""Do you mean the gauge of the material, or do you mean the cap is narrower at the top?""""""""""
Thats a good question!
Although, tapering the object is not terribly complex:
I could see though some command that does this with a "widget" if it's something that you do all day, all the time.
6277.11 In reply to 6277.10
What is your method of tapering?
6277.12 In reply to 6277.11
Did you ask me Frenchy?
I used flow from a square plane to a tapered plane.
6277.13 In reply to 6277.12
Cool that was the trick! ;)
6277.14
Oh good grief!
There you go, you see.. I was sure I was just ignorant of the method to do the tapering.
You hit it bang on the head with the square plane and the flow technique! The problem is I'm still clueless as to how you did it (believe me.. I thought I'd tried everything with flow.)
With no proper tutorial or documentation on how flow could be used, it's actually a very confusing process if trying to learn by trial and error. Honestly, I've been modeling since the 90's and this one had me stumped..
Is there any chance you could describe your method ? I'm sure it's painfully obvious, but you're a better man than me there !
:) /RH
6277.15 In reply to 6277.14
Yes after a little headache I have found that! With the original file from Burr
Maybe like this! :)
Copy B to C on the left - move Points then all works fine! if you copy on the right that don't work! :)
Flow is a command little capricious if you don't take it on the good way! :)
EDITED: 13 Nov 2013 by PILOU
6277.16 In reply to 6277.15
Here is a video of it:
Create plane and copy and paste. start line and use tab to angle field.
6277.17 In reply to 6277.15
""""""""" if you copy on the right that don't work!"""""""""
Probably depends on where you clcik your surfaces during the flow command. Or even how you made your surfaces, like "dragging from top down or left to right"...........
6277.18 In reply to 6277.17
That is very mysterious now that works even I put the copy on the right, on the left, in front of, or even behind!!
6277.19 In reply to 6277.3
Hi Rico, I'm glad you're getting more use out of MoI for modeling now!
As you've seen above you can get bending or tapering done currently using the Flow command.
For bending it's fairly straightforward, you draw a straight line down the middle of your shape, and then a curved line for how you want the bent result. Then select your object you want to bend, run Transform > Deform > Flow, then select the line as the base for the Flow and the bent curve as the target for the Flow and that will bend your object along that curve.
This allows for a whole lot of flexibility since you can bend along any kind of curve, not just necessarily an arc shape.
See here for some bending examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.246
http://moi3d.com/forum/index.php?webtag=MOI&msg=5097.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=5130.5
Tapering can also be done with Flow, using the other mode of Flow where you select base and target _surfaces_ instead of using curves. This is kind of more involved, Burr shows the method above though.
In the future I want to add a "cage edit" tool which I think will be a more convenient way to do tapering as well. But until the time that is ready the method Burr shows above is how you can get it done now.
Curve to curve flow works well enough for bending that I don't think it's likely that there will be a separate Bend tool (well maybe as an optional plug-in). You just get so much more flexibility when the bent shape is defined by a curve that you can draw and customize rather than only bending around and arc shape. One of the main strategies for keeping MoI to have a light and fluid feeling in its UI is to try and get broader use out of a smaller number of tools...
6277.20 In reply to 6277.4
> I believe that Michael is coding some cage or box of deformation! ;)
I am not coding it right this very minute, but it is something that I want to add in the future.
6277.21 In reply to 6277.18
Well Frenchy, The french are always mysterious with their fine wines and cheeses and the alure of women and such...
6277.22 In reply to 6277.18
It's only in "Projective" mode of surface-to-surface Flow that the specific placement of the base or target surface makes any difference.
In the regular mode that's being used here, it does not make any difference specifically where you have located the target plane.
If you're seeing differences it's probably because you're clicking in slightly different spots on the base and target surfaces - the pick point for where you click each one is significant, see here for an explanation of where to click on each one to match things up properly:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5853.1
6277.23 In reply to 6277.22
Thanks, I have never seen this post! That was not evident!
6277.24
Another method with history...
EDITED: 18 Oct 2018 by SBEECH
6277.25 In reply to 6277.20
Thank you guys SO much for the feedback and education.
And Michael, sorry for the scare there. I absolutely believed the facility was there, just not immediately apparent. You've already made sure everything else is present that I could think of in MOI, so how could that have been missed ? It wasn't :)
Your implementation really is elegant.. it was just missing the tutorial Burr posted (thank you so much, Burr). I'm beaming right now, and feel empowered again. It was the same feeling I got when discovering the power of your implementation of curves and Booleans.
Another question:
How did you make an industry level competing CAD program as enjoyable and addictive as Lego?
Sorry for gushing, but to me that's real genius.
6277.26 In reply to 6277.24
@Danperk
Elegant method!
6277.27 In reply to 6277.24
Dammit.. now I've just discovered flow with history.
Even more addicted. I suspect my wife will soon learn to dislike MOI
6277.28 In reply to 6277.25
Hi Rico,
Actually it wasn't there in version 2.0, it's one of the new things added in for the v3 period.
I'm still in the process of adding in a lot of things!
> Another question:
:) That's awesome that you're having fun with it!
Early on I had a big focus with MoI of trying to get a nice and fluid feeling while drawing things. That doesn't necessarily come from any one single thing, just from a lot of little things added together and having a big priority on avoiding things that feel clunky or feel like they're interrupting the process. It helps to keep more of a feeling of having fun with things rather than a feeling of a constant struggle, at least that's the goal.
I'm glad you're getting into the groove with it!
6277.29
Thanks Pilou!
As Martin & Burr mentioned, the flow taper should be done first to the outer shell of the base object.
Then the tapered object could be shelled to the correct thickness to avoid distortion of the gauge.
Show messages:  1-9  10-29  30-32
