Resolution of Image View of PNG file
All  1-3  4-8
6276.4 In reply to 6276.1
Hi Brian, is the first image that you attached the image you're using?
That image is only 687 by 480 pixels in size, which is pretty low resolution, with an image of a low pixel density like that each pixel will end up being kind of large on the MoI viewport and the bilinear blending effect will be exaggerated.
Are you cropping out a small area of the scan to get this particular image? If you want it to be clearer it just has to be higher resolution, if there are more pixels in the image the individual pixels will not stretch out to as large of an area in the MoI viewport.
It can be problematic to have images that are excessively large as well but you would probably want to shoot for something more in the 1500 or 2000 pixels in width and height to get a better viewport display of it.
The posted images are just very small snips of the overall scan of the purchased plans, in order to show the relative level of "blurriness" or "clarity" of the 3 different display methods of the original PDF, and PNG exported from the PDF. The middle one is the MoI Image version of the PNG.
The purchased plans allow models to be created, but the plans cannot be disseminated. They were hand drafted a few decades ago, to 1:8 scale, and one Black and White "blueprint" page measures about 25" X 36." The pdf is described as 400 dpi, and looks fairly clear. The png from the pdf, is 3,542 kbytes, and looks fairly clear also. The MoI version is still very useable, but I thought I would check on how it is displayed, as the way the curve pixels are displayed seems very "different" from the other two views.
I'll try the tracing method later today. Edit: The file is too big for autotracer.
Here is a small snip of the MoI top view of a test DXF created from the PNG by the free version of the program PDFtoDWGConverter. This display shows up very clearly in MoI, although the converted curves are not how they should be, which is no fault of MoI. (I understand that this view is of a ("vector trace"?) DXF, not a PNG).
Thank you
6276.6 In reply to 6276.5
Miro before painting! :)
6276.7 In reply to 6276.3
Michael, thank you for the information. Did a little google research. A couple of explanations:
Circa 2005: http://www.chadvernon.com/blog/resources/managed-directx-2/texture-compression-filters-and-transformations/
Up to date: http://msdn.microsoft.com/en-us/library/bb206250.aspx
It seems that turning off "bilinear interpolation" would require changing the MoI program as to how it uses Direct3D9 ( or DirectX?),
and maybe the result would be very poor anyway?
Read that NVIDIA video cards do not allow disabling of bilinear filters.
So I'll probably proceed using the filtered PDF textures, and guess at where to place the MoI Nurbs curves. The difference in location
is, (at a rough guess), say maybe 1/100 of an inch, and the plans are not perfect anyway. The Nurbs curves will be nice and crisp.
6276.8 In reply to 6276.7
Yeah that's correct - currently MoI turns on bilinear interpolation when it sets up things for Direct3D and there isn't any method set up right now to turn it off.
When turned off you end up with "nearest neighbor" filtering which tends to be very heavily blocky and jaggedy. Things that look blurry to you right now instead be big jagged stair steps.
The main thing you need to do to get a better quality screen image is to get a higher resolution image to work with, the image that you're working with at the start of this thread here is too low in pixel count to get a good display, you basically need more pixel dots in order for the pixel structure of the image to not be so visible on the display.
If you have a really large plan then you may need to work on it in some separate pieces so that you can have a higher resolution (with a higher pixel count, again something like 2000x2000 instead of 600 pixels across like your image above) scan of each piece.
Show messages: All  1-3  4-8
