STL save as assembly
 1-3  4-23  24-28
6270.24 In reply to 6270.23
That is sure a nice printer you've got there.
6270.25
It shows off your software nicely
6270.26
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
6270.27 In reply to 6270.26
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
6270.28 In reply to 6270.27
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
Show messages:  1-3  4-23  24-28
