Can´t open
All  1-17  18-19
626.18 In reply to 626.17
I had MOI reinstalled and now it works fine!
> Is there any crash report generated in your %TEMP% folder?
So, I checked %TEMP% folder but it was after reinstalling MOI, & nothing was there!
> If your machine is pretty old it would be good to do some checks on the hard disk and memory to start with
My machine is old, but I believe its hardware is still fine & it is not affected by dust (that's what I believe!)
I believe windows might have corrupted! My problems started to show up after I tried to remove Fusion 360 from my machine!
Here I had talked about it: http://moi3d.com/forum/index.php?webtag=MOI&msg=9952.29
Anyway for now MOI is working :)
And soon I believe I will reinstall Windows.
626.19 In reply to 626.18
Hi Psygorn, well apps mysteriously getting corrupted is not a good sign. Hard drives don't last forever and if yours is pretty old it might be starting to fail.
You should probably do a disk check and it would not be a bad idea to just replace it now while you can still get stuff off of the old one.
Hard disk is generally the system component that is most likely to fail when your system gets pretty old.
Show messages: All  1-17  18-19
