shortcut for changing the view window
All  1-2  3-5
6248.3 In reply to 6248.1
Also if you want to set up the reversed views (Bottom, Back, Left) on an individual key too see this post:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3808.2
6248.4
Thanks Michael and Andrei,
works a charm!
rgds
wim
6248.5
This is a good option to select viewport , assigned to space key it is very fast
Whichever view the mouse pointer is over when space bar is pushed is selected , space again back to 4 panes
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
cheers
shayne
Show messages: All  1-2  3-5
