shortcut for changing the view window
6248.1
I thought this would be obvious to find a similar request or question in the threads, but didn't find.
is there a way to make a keyboard shortcut to change window views, e.g. from top view to 3D view? or a command to do this?
I am working with an Xkeys programmable keyboard and would like to put those under a key, like in other 3D programs.
thanks
wim
6248.2 In reply to 6248.1
Assign this:
moi.ui.mainWindow.viewpanel.mode = 'top'
moi.ui.mainWindow.viewpanel.mode = '3d'
moi.ui.mainWindow.viewpanel.mode = 'front'
moi.ui.mainWindow.viewpanel.mode = 'right'
Portfolio: www.samardac.tumblr.com
6248.3 In reply to 6248.1
Also if you want to set up the reversed views (Bottom, Back, Left) on an individual key too see this post:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3808.2
6248.4
Thanks Michael and Andrei,
works a charm!
rgds
wim
6248.5
This is a good option to select viewport , assigned to space key it is very fast
Whichever view the mouse pointer is over when space bar is pushed is selected , space again back to 4 panes
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
cheers
shayne
