AquaRiva
 1-2  3-22  23-42  43
6236.23 In reply to 6236.19
Excellent renders, well worth adding to your portfolio - Well done Andrei
Martin Spencer-Ford
Very cool result!
Maybe a little more reflecting on the wood's parts ?
EDITED: 5 Nov 2013 by PILOU
6236.25 In reply to 6236.24
Here is a teak table with a soft polished luster. Not far off at all. ;-)
6236.26
Thank you)
Portfolio: www.samardac.tumblr.com
6236.27 In reply to 6236.26
No words to describe the pleasure.
(I'm from Italy, so there'a little bit of pride...=)
Also, as a car modeling fanatic, I invite you to use your skills to show us another wonderful work...
6236.28 In reply to 6236.27
Boja, thank you))
6236.29
Andrei,
I echo all the other compliments on this work. As Mike said, you are an inspiration! May I ask what rendering program you use?
Best,
Ron
6236.30 In reply to 6236.29
I believe that is VRay for C4D ;)
6236.31
Gorgeous!
6236.32 In reply to 6236.29
Ronamodeler (RON_A), No It is just Standart render engine :) It rendered about 1 minute :)
6236.33 In reply to 6236.32
Andrei Awesome!!!
Thanks for the video too bro...
One question....I just dont understand how you got the ends closed on your hull loft, especially the front . I used the same settings as you (loose and exact) but the nose remained open.
Did you loft to a point?
6236.34 In reply to 6236.33
niko, yep I used loft to point. Try it, Michael made it works very good.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6236.35
Yes it is great but it breaks history...No adjustments can be made, so I guess you tweak your profiles and then reloft when u are done tweaking?
6236.36 In reply to 6236.35
Yep, I work A LOT with Loft but never noticed it may be it appear in last version, do not know.
Michael, what it can be, it is impossible to modify loft object, when I try to move curves, it creates cap instead of conect it to point.
6236.37 In reply to 6236.36
It's a bug where the point objects are not being registered as part of the inputs for the loft, so during the history recalculation only the curves get used and not the points.
But I've got this bug fixed up for the next v3 beta now.
6236.38
Wow :)
6236.39 In reply to 6236.19
That is awesome......
Which renderer did you use?
Peace,
Rich_Art. ;-)
6236.40 In reply to 6236.39
Rich_Art,
Just Standart Render from C4D.
6236.41 In reply to 6236.40
That is cool.. I love your work. When I see this I feel the urge to fire up C4D again..
Would love to see some rendersettings. ;-)
Peace,
Rich_Art. ;-)
6236.42 In reply to 6236.41
Rich_Art, I practically always use AO contrast at 50. And at final render put Samples at 150, but during tunig set it to 50.
Aslo I set this settings to minimum, it makes render very fast... Quality stay preatty good. Some times very rary it produce some artifacts if so just increas it a bit... But it happens really very rare.
All other settings stay untached.
I use R14, in R15 something was changed and this settings does not work.
Show messages:  1-2  3-22  23-42  43
