AquaRiva
 1-18  19-38  39-43
6236.19
Thanx) And rendered one)
Image Hosted by ImageShack.us
6236.20
Looks beautiful with some color on it.
Great work all around.
~Kevin~
6236.21
Andrei... You are my inspiration!
It's very beautiful!
6236.22 In reply to 6236.20
I agree. Excellent model and render.
Next - maybe render in water?
Ed
6236.23 In reply to 6236.19
Excellent renders, well worth adding to your portfolio - Well done Andrei
Martin Spencer-Ford
Very cool result!
Maybe a little more reflecting on the wood's parts ?
EDITED: 5 Nov 2013 by PILOU
6236.25 In reply to 6236.24
Here is a teak table with a soft polished luster. Not far off at all. ;-)
6236.26
Thank you)
Portfolio: www.samardac.tumblr.com
6236.27 In reply to 6236.26
No words to describe the pleasure.
(I'm from Italy, so there'a little bit of pride...=)
Also, as a car modeling fanatic, I invite you to use your skills to show us another wonderful work...
6236.28 In reply to 6236.27
Boja, thank you))
6236.29
Andrei,
I echo all the other compliments on this work. As Mike said, you are an inspiration! May I ask what rendering program you use?
Best,
Ron
6236.30 In reply to 6236.29
I believe that is VRay for C4D ;)
6236.31
Gorgeous!
6236.32 In reply to 6236.29
Ronamodeler (RON_A), No It is just Standart render engine :) It rendered about 1 minute :)
6236.33 In reply to 6236.32
Andrei Awesome!!!
Thanks for the video too bro...
One question....I just dont understand how you got the ends closed on your hull loft, especially the front . I used the same settings as you (loose and exact) but the nose remained open.
Did you loft to a point?
6236.34 In reply to 6236.33
niko, yep I used loft to point. Try it, Michael made it works very good.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6236.35
Yes it is great but it breaks history...No adjustments can be made, so I guess you tweak your profiles and then reloft when u are done tweaking?
6236.36 In reply to 6236.35
Yep, I work A LOT with Loft but never noticed it may be it appear in last version, do not know.
Michael, what it can be, it is impossible to modify loft object, when I try to move curves, it creates cap instead of conect it to point.
6236.37 In reply to 6236.36
It's a bug where the point objects are not being registered as part of the inputs for the loft, so during the history recalculation only the curves get used and not the points.
But I've got this bug fixed up for the next v3 beta now.
6236.38
Wow :)
Show messages:  1-18  19-38  39-43
