print on paper
All  1-3  4-6
6228.4
A fast way to print that does an OK job is to use gadwin printscreen program , where you can select the whole screen or area to print and it will save as a picture file and or send it to print.
Its free from http://www.gadwin.com/printscreen/
Even on my cheap laser printer the results aren't too bad
cheers
shayne
6228.5 In reply to 6228.4
Hey Shayno,
It can still be better to use the screen capture script inside of MoI, because you can set the resolution of the captured screen in the script.
script: /* render view to clipboard */ var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
The limitation will be at the card. But better than doing a screen grab of the monitor.
6228.6
Thanks to all for your reply. I Will try it When I am back from travel..
Show messages: All  1-3  4-6
