Auto Selection?
All  1-2  3-7
6218.3 In reply to 6218.2
Thank for the reply Michael. I didn't think there was a way to do it but thought I'd ask since I am facing hours of clicking. Still, it is faster than trying to do it in Illustrator. This is the shape I need to end up with. Sort of a zigzag path back and forth. It will be used for water jet etching.
6218.4 In reply to 6218.3
Did some searching.
Looks like this is like "zig zag milling" with a "linked tool path."
Tool-path planning for direction-parallel area milling
http://vms.kaist.ac.kr/publications/Journal/[27]%20CAD-00-DParea.pdf
Very preliminarily, it looks like parallel lines are used to get the nodes, which are then linked up
for the path...
6218.5 In reply to 6218.3
Hi Terry,
So another way to do it would be to generate a planar toolpath on a "surface" and post code for it, then a guy wrote a program that will generate a dxf file off of your gcode, which you can use at the waterjet. (There are some free cam programs to get the code if you dont have something like that)
The program is here on the cnczone forum:
http://www.cnczone.com/forums/opensource_software/8814-g-code_dxf-2.html#post183370
Some of the links will require an account made to log in to download it. He has it listed as open, but not sure if I can just post it here. Probably better left to aquire it from the source.
The dxf can be imported to MoI if you need to further work it...
6218.6
Thanks for the suggestions guys.
Terry
Studied the paper quite a bit, and looked at the plane sweep paradigm algorithm(s).
Starting with a letter, lines which will become tool paths can be arrayed.
One use of the intersect script can find all the points, but may not be needed.
Using Boolean intersect, all of the tool path line elements i,j can be made from the lines.
Using trim, all of the boundary curve segments can be created, of which about half are used.
A list or array of all of the left and right endpoints of the line elements would need to be made. (MoI knows the start and end points)
A list or array of all of the left (upper) and right endpoints of the boundary curve segments would be needed.
Select a start point and generate the sub-path, using points which match and a few simple rules. Repeat loop.
Some of the uppermost, and lowermost boundary curve segments may need some tweaking.
So a script could probably be done, with a lot of work(?)
Had some fun manually creating some zigzags.
Show messages: All  1-2  3-7
