UmbilicTorusScript and creating a solid
All  1-2  3-6
Seems there is a glitch inside the UmbilicTorus when I ask a Closed Loft!
PS What was your regulates for the Unwrap method Circle--> Extrude / Hypotrochoid ? (so no need to strech)
120° of Twist ?
I have a little difference in making one pass!
Normally this must not arrive?
EDITED: 6 Jan 2014 by PILOU
6217.4 In reply to 6217.3
Response based upon memory only :-)
Was unable to do a one step loft. In order to get the solid, had to resort to Boolean union of separate parts.
Do not know why. Something like a torus of circles would only take one step.
Do not understand the "unwrap" question. Recall that 120 degrees was used for something.
The modular arithmetic may help make the 3 corners more equal in shape, since due to the rotation,
different corners meet up.
EDITED: 6 Jan 2014 by BEMFARMER
6217.5 In reply to 6217.4
< the unwrap question
Just
I draw a circle : UnwrapCurve : so I have the length of the extrusion of the volume for Twist it! :)
Then Flow along the circle
But the closed form is not perfect against your is marvelous!
6217.6 In reply to 6217.5
Hi Pilou
Your are correct, the Flow does not result in a perfect connection.
Zooming in on the UTFlow one that I did, shows that the connection is NOT perfect. :-(
I see that using the stretch option did create a solid. Still imperfect though.
Show messages: All  1-2  3-6
