Rail Sweep
All  1  2-6
6212.2 In reply to 6212.1
Hi gunter, is it possible for you to post an attachment with your 3DM model file in it rather than only screenshots? It's a lot easier to examine a model file to see what you might be running into.
Are you doing a one-rail sweep or a two rail sweep?
For something like that you'd want to do a 2 rail sweep, with the profile curve for the sweep like this:
And then 2 rails going up something similar to this (shown separated here for illustration):
If your vertical curve is currently just one single curve, you can use Edit > Trim to cut it into 2 pieces so it will be configured for 2 rails like I show above. Select it and run Edit > Trim and then click the "Add trim points" button and add a trim point at the spot to cut it.
Another possibility for a cap like that is to use rail revolve, for that you have a profile and bottom rail like this:
You select the profile there, run Construct > Revolve > Rail revolve, select the rail path and then pick the revolve axis which you want to pick dropping down from the tip of the profile curve. That will then make a cap by pivoting the profile around the axis and stretching it to follow the rail path as it pivots.
Also in some cases the new Construct > Nsided command can be used for putting on a rounded cap as well.
6212.3 In reply to 6212.1
In this case it's better to post the file 3dm ;)
Maybe Rail Revolve works ?
or the new Nsided ?
or Blend
or...
Ps Cross post :)
6212.4 In reply to 6212.1
hi there!
you could try to use the Rail revolve tool..
there could be some continuity issues regarding the transition from the main part though..upps, just saw Michaels reply..
so that would be the "other" Rail revolve solution with a bit of trimming involved..
~marco
EDITED: 9 Oct 2013 by MARCO
6212.5 In reply to 6212.4
Maro,
Thank you so much for your effort. It works great.
You guys are awesome!
Gunter
6212.6 In reply to 6212.2
Michael,
Really appreciate your reply. Thanks very much! It works.
Gunter
Show messages: All  1  2-6
