unit (mm - meter) question
6210.1
I mostly model in the mm unit mode, but when I export my obj file, the object is a 1000 times too big. changing the prefs to meter at that point does not only change the units, it also changes the size of the objects, so problem remains.
I thought that opening a fresh document in meter units, then copy paste my objects into it would save the problem, but it doesn't.
there even is a funny glitch then, I cannot select objects anymore, just rotate view, zoom and pan. restarting the program is the only option.
is there a way to export objects when drawn in mm units, without having to scale it down a 1000 times first?
tnx
wim
6210.2 In reply to 6210.1
hi wim..
you just have to deselect the "Scale on unit system change" option in the Unit options dialog..
~ marco
6210.3 In reply to 6210.1
Check the import/export settings under options. There is a scale setting for OBJ
Martin Spencer-Ford
6210.4 In reply to 6210.2
ouch! I should have found that by myself, shouldn't I? Thanks Marco, great help!
wim
6210.5 In reply to 6210.3
thanks Martin,
I should have looked there, but it would be logical to find it with the obj export settings when saving. my mistake.
Wim
