extrude or planar problem
6208.1
I am trying to extrude a path with cap ends, or first make it planar and then extrude, but the program won't let me. the inner shape to be extruded is derived from the outer one with the offset tool. the outer one works fine, the inner one only extrudes without the cap ends.
any ideas why this won't work?
tnx
wim
6208.2 In reply to 6208.1
The inner curve is not closed. There is a tiny error.
Use MarkOpenCurveStart script, or MarkCurveStart to help find it.
Edit: The unJoined curve shows two extra tiny line segments...
EDITED: 4 Oct 2013 by BEMFARMER
6208.3 In reply to 6208.2
Thanks bemfarmer! I found it (by eye, without the script, that is too complicated for me ;-)
but it is funny, the outer curve is completely symmetrical (done with mirror) so I would expect that the error in the derived curve would be symmetrical too, and in that case the object should show as 2 curves, it should be broken at 2 places. that is why I did not think of an open curve at first.
thanks again!
wim
6208.4 In reply to 6208.3
Tried a different offset. Seems like the intersecting line segments which are very nearly a straight line, but not quite, are
not being trimmed by the offset command ??
6208.5 In reply to 6208.4
It's often times difficult for intersection mechanisms to get a clean intersection on things that are very nearly tangent with one another but not quite.
That's because things like that have a kind of "zone of intersection" where the 2 objects are within the target tolerance of each other across some extended area rather than at a sharply defined point.
