Working on curved surfaces
All  1-3  4-7
6200.4 In reply to 6200.3
Hi Andrei,
> Yep Michael I know about this but if surface is very curved I have to orient all profiles along it to get more
> good result, but it is still not very precise method.
Still, it's the main method currently, either that or Flow if you have a more detailed pattern that you want to map on to a curved surface.
You can also use the Transform > Orient command to help with positioning a planar profile onto a surface so that a center point of it aligns to the surface normal.
See here for some examples of the Orient command:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3977.2
If the surface is very curved then mostly you'll probably want to use Flow instead.
6200.5
We also had some discussion about this very topic here where you can configure your ini file to draw in ortho view.
Bit of a pain I know, but does work well.
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6171.1
Those shapes you've drawn do seem like an ideal candidate for flow but if you've already tried it, then how about making your curved shape, giving it thickness and then drawing a temporary construction planes where you want the holes and then Boolean the holes.
EDITED: 28 Sep 2013 by KEVJON
6200.6 In reply to 6200.5
Thanx) Kevjon, what does it mean draw in ortho view?
Portfolio: www.samardac.tumblr.com
6200.7 In reply to 6200.6
Draw a curve on a surface in ortho view.
Moi normally only allows you to draw a curve on a surface in perspective view.
~Kevin~
Show messages: All  1-3  4-7
