Temporarily lock move along direction
All  1-4  5-7
6191.5 In reply to 6191.1
Hi Max, for the next v3 beta I've implemented a shift "Straight snap enhancer" which I think will do what you want.
The way it works is if you have a straight snap currently active, you can then hold down shift and that current straight snap will stay engaged while shift is still held down, no matter how far your mouse moves away from the line. It also will ignore any object snaps that are not on that line while shift is held down. Object snaps that are directly on that same line will still engage.
Also if you push shift when straight snap is not currently engaged at all, it will enable straight snap to the nearest line.
> Often I happen to have to move an object along, for example, the Z axis, or the surface's normal.
> I would like to lock the moving along that direction.
Yeah it should work for this kind of use - the way you'll use it is to move your mouse around as you currently do to activate the particular straight snap that you want like z axis or surface normal or whatever, then hold down shift and that one will stay locked in while you keep shift down.
So that's coming for the next v3 beta.
6191.6 In reply to 6191.3
Hi max,
> But often there are snaps nearby and I just lose the direction for a while, so I want to
> lock it along that direction so I never have to pick that up again if I lose it.
Yeah the next beta should solve this - basically when shift is down it will both lock the current straight snap line to be active and also while it's down straight snap has a higher priority and object snaps won't be targeted unless they are right on that active straight snap line.
6191.7 In reply to 6191.5
That's exactly what I needed, thanks!
Great work.
Show messages: All  1-4  5-7
