Astonished free mechanical prog
 1-12  13-32  33-52  53-72  73-75
6186.13 In reply to 6186.12
Yes in Moi, Pushpull the "face" created after the Fillet is automatic! :)
The problem for me is make the same inside DesignPark!
And this at first view is impossible directly as I understand for the moment! ;)
Maybe there is a parameter to enable somethere...for make this possible...
EDITED: 16 Apr 2018 by PILOU
6186.14 In reply to 6186.13
Hi Pilou, sorry I don't know how to get that same behavior from SpaceClaim, it seems that it wants to move the fillet as well by default?
Maybe try holding down Ctrl or Alt when you do the pull, does that do anything differently?
You may need to ask in the DesignSpark or SpaceClaim forums to get a proper answer on that.
6186.15 In reply to 6186.14
I have found! :)
But not sure that will work more speedy than my first "duplicate" above! :)
You must select strictly 3 edges!!! (1, 2, 4 don't work)
6186.16 In reply to 6186.15
Hey Frenchy,
Just include the edge that belongs to the fillet in the selection. So, Select face, then Ctrl click the edge that you want to go along with the extrude.
6186.17 In reply to 6186.16
You rocks! (click first the edge then Select face with Crtl works also! ;)
A little trick for the "Only read file STEP imported"!
Import the STEP file created in Moi ;)
Add a solid to the drawing (cube, cylinder, sphere, whatever).
Right click on the top-most name of the component tree (the name of the whole thing).
Unlock. Everything in the tree is now unlocked.
Just to change the not cuty Black color! :)
6186.19 In reply to 6186.18
Frenchy's going Black Hat!!!!!!! Heaven help us........ :)
@Burr:)
Amazing thing: you have the export in PDF 3D!!!
So Moi format Step in PDF 3D ! ;) (or of course anything that you have in DesignSpark)
Inside DesignSpark : Menu File/ Save as PDF faceted Geometry
The file PDF3D: http://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub2.zip
EDITED: 4 Apr 2015 by PILOU
6186.21
cool
6186.22 In reply to 6186.11
Direct editing... my software (Geomagic Design) does this too. Many software's do.
Design Spark isn't bad actually but just nowhere near as good as paid-for software.
In V2 Blend Function is missing so Install first V1 http://zwcad.com.tw/nick/FREE3D/
then V2
Edit : Seems this site is not more accssible!
EDITED: 2 Jan 2017 by PILOU
And something else!
So you can make cotation of Moi object!
In 2D or 3D! Then export in DXF or PNG!
by Chri
Here direct export in the free DraftSight
As the blue plane frame is automatically hidden when you print
you must hide it like this if you want save an image PNG !
Select it = open context properties then disable Contour!
Sorry in French but in your version that will be in English! :)
So you can now have very easily have neat measures for Moi projects! :)
(even some strong fillets before new versions! ;)
Very exotic method for see the volume of an object!
You must have 2 volumes minimum
And for see the last of a serial you must copy it!!!
For use the Blend function you must use the previous Version!
DesignSpark Mechanichal 1 !
Edit:Seems this site is not more accessible!
go there for see the animation! (and click on the image for start the animation) ;)
http://moiscript.weebly.com/designspark.html
6186.29
DesignSpark Mechanical is quite limited, so I'm trying to migrate from DSM to Moi3d :-)
Anyway I wonder what is problem with loading this sat file http://ixion.pld-linux.org/~arekm/bulk-cable-holder.sat in moi3d.
It was converted from DSM rsdoc using known SabSatConvert.exe method - https://github.com/arekm/rsdoc-to-sat
Loading it in moi3d displays no error, but also no model is shown. Where is the problem? I would expect at least some error message.
More rsdoc files to test conversion to moi3d here: http://www.thingiverse.com/lamer/collections/rsdoc (some work, some do not)
ps. I'm new to 3d design. Trying to create models for 3d printing (hobby). moi3d looks great - learning phase here.
So far didn't find anything better in 500$ price range, so I plan to buy moi3d when trial ends. Thanks for great software!
6186.30 In reply to 6186.29
Hi arekm,
It seems to be an invalid ACIS file - I tried reading it into ViaCAD and it does not read it either - ViaCAD reports "ACIS READ FILE SURFACE DATA ERROR".
I'm not all that intimately familiar with ACIS files so I'm not 100% sure what the specific problem is, but it's likely to be either it's a customized variant of SAT format intended to prevent file transfer to other programs (DesignSpark is intended to have limited file transfer abilities), or it may be using features from a newer version of ACIS (ACIS is the geometry library where SAT files originate from) than what either MoI or ViaCAD supports.
If it's because of using newer and unrecognized versions of ACIS entities in the file, that can usually be solved with regular file transfers by setting an option for what particular version of ACIS to target with the generated .sat file - setting it to something like SAT version 8 will then be more likely to use entity types that will be recognized by MoI's ACIS format reader. But since DesignSpark is specifically designed to limit file transfer abilities they probably don't have any options for that in that particular package.
6186.31 In reply to 6186.30
Indeded - no option for version in DSM. I'll try with sabsatconver.exe from DesignSpark Mechanical 1.0 - maybe older version produces older sat format, too.
ps. works with https://sharecad.org/ viewer
I have tested :)
DSM2 --> Transform by Sab converter dsm1 or Sab converter Dsm2) --> Moi, Onshape: No
DSM 1 -->Transform by Sab converter Dsm1 or Sab converter Dsm2) --> Moi, Onshape: OK
So modelize in DSm1 old! Or use the Pro version of Space Claim ! ;)
EDITED: 2 Jun 2015 by PILOU
Show messages:  1-12  13-32  33-52  53-72  73-75
