copy and paste
All  1-7  8-10
6181.8 In reply to 6181.7
Hey,
Thanks Marc!
6181.9
Hello,
Sorry for digging up old thread.
Im new to moi scripting, i do however have some maxscript and c# experience.
For now, I have no idea why the modification of above script doesnt work, and im not sure if its related to moi behaviour, or my rusted skills:
script:
/* Duplicate selected objects */
var gd = moi.geometryDatabase;
var objs = gd.getSelectedObjects();
if ( objs.length != 0 ) gd.copyToClipboard( objs );
moi.command.execCommand( 'paste' );
objs =gd.getSelectedObjects();
if ( objs.length != 0 ) moi.command.execCommand( 'Move' );
all i want is for this script AFTER pasting the copy to immidiately enter move command - it enters, but for original object, and actually doesnt duplicate the the object. If i remove last 2 lines (i've already tried just simply "moi.command.execCommand( 'Move' );" ) and "move" assuming it should be already selected, but result was identical.
Any help welcome, thanks!
6181.10 In reply to 6181.9
Hi propiro,
script:
The problem is that execCommand is not synchronous, so as to avoid one command from running while still inside another one.
So execCommand sets some flags and then the command is only actually launched when on a clean call stack.
But instead of using execCommand( 'paste' ) you can use the direct script code for what the Paste.js command does internally which is:
moi.geometryDatabase.pasteFromClipboard();
There are also some other already existing ways to duplicate objects similar to this - the Transform > Copy command or also holding down the Ctrl key when you click and drag on an object will drag off a duplicate.
Show messages: All  1-7  8-10
