Also some other tips - for your case here if you go to the Front or Right side views it will probably be easiest to grab lots of little hole faces that way.
And also normally you need to click in empty space for the initial mouse down when you want to start a window select. If you click down on an actual object, you won't get a window you'll get a selection result from the click.
But if you hold down shift+ctrl when you click it will force window selection to happen so if you do not have any convenient empty space to do the initial click, hold down shift+ctrl to do a window select and when you do that it doesn't matter where the initial click is on.
