Planar then select surfaces
All  1  2-4
6169.2 In reply to 6169.1
Hi DesuDeus,
> Is it possible to have a small script that does three things.
> 1. Planar
> 2. Delete curves used for planar
> 3. Select resulting surfaces
I've attached a plug-in command that will do this - copy the attached file PlanarWithDelete.js into the \commands folder inside of MoI's main installation folder.
That will then make a new command available named PlanarWithDelete which you can set up a shortcut key to call, it should behave how you describe.
6169.3 In reply to 6169.2
Thanks a lot ! will try that on monday morning :)
shapenoid.com stojan-voumard.com
6169.4 In reply to 6169.3
I slighted edited the script to only selecting the resulting surfaces, it comes a lot handy for architectural use (solid hatches) thank you!
Show messages: All  1  2-4
