Hi DesuDeus,
> Is it possible to have a small script that does three things.
> 1. Planar
> 2. Delete curves used for planar
> 3. Select resulting surfaces
I've attached a plug-in command that will do this - copy the attached file PlanarWithDelete.js into the \commands folder inside of MoI's main installation folder.
That will then make a new command available named PlanarWithDelete which you can set up a shortcut key to call, it should behave how you describe.
