ui
6168.1
I have cleaned up my ui a bit and am in fact happy right now, but if 3 little things are possible that would be great, too.
1. Can I snap/move my "Tool Box" to the bottom of my window's frame?
2. Can I remove the little margin at the top?
3. Can I remove the filename in SidePaneHeader.htm?
Edit: Sorry for the bad title.
6168.2 In reply to 6168.1
Hi Strube, are you using MoI v2 or v3? The side pane UI is structured a little differently between these versions and so the answers to your questions are a bit different depending on which version you're using.
Also if you can post your modified side pane files that would probably make it easier to help you as well.
6168.3 In reply to 6168.2
Hi, I am getting a license when my trial is expired and then of course I am going to install v3. I'll ask again then.
