how to cap oval
All  1  2-11
6167.2 In reply to 6167.1
Hi Mrjynx,
If the representative bridging profile curves (the ribs) are all separate (x 4) - if they start at the ring, then meet in the center it should work with Network.
6167.3 In reply to 6167.2
Id like to be able to control the bulge like I would with the slider in network.
if I don't have the 4 profile curves and I just have an open oval and want to create an oval bulge, whats the quickest way to do it.
am I going to have to draw 4 profile curves each time?
6167.4 In reply to 6167.1
Sorry, I spoke too soon...
This has worked for me many times, but in this case I tried to break it by making sure the control curves were not very uniform.
The bottom dome was successfully created by Network with a profile ring and four separate profile ribs.
The top Network failed even though I made sure that ALL end-points touched.
It may have something to do with the fact that the control ring is not very flat.
You should present your model's .3dm file for others to work with. My attempt is made available here for any to solve more gracefully.
http://k4icy.com/Moi3D_Tutorials/ex_01aN1.3dm
6167.5 In reply to 6167.3
With the Blend tool!
Cut the profile ring into two pieces.
Note: as of yet, the newest beta release of MoI will have an issue with blending two (a dual pair - no other adjoining sections) edge curves that touch.
EDITED: 12 Sep 2013 by MAJIKMIKE
6167.6 In reply to 6167.5
Oh I see... blend yes... right thanks!
6167.7 In reply to 6167.5
Mike how did you make this cap transparent?
Portfolio: www.samardac.tumblr.com
6167.8 In reply to 6167.6
I've made a short video on what you can also do here. Using Rail Revolve: http://goo.gl/hnJpz9
6167.9 In reply to 6167.8
Interesting alternate way thanks.
6167.10 In reply to 6167.7
Two screen captures and some Photoshop. ;-)
Why not only an oval + a profil + Rail Revolve ?
Show messages: All  1  2-11
