Choppy navigation
All  1-3  4-9
6159.4 In reply to 6159.3
Hi Mike, MoI does use the video card for it's display, you might try updating your video drivers to the most current one and see if that has any effect.
Also maybe some kind of anti-virus or anti-malware type system that you're running is having some negative performance effect. If you're running any kind of utility like those that hooks into programs at a low level try disabling it temporarily and see if that helps or not.
Maybe when you run MoI early in the boot up process whatever other software is bogging things down has not gotten up and running at that time, that's kind of what it sounds like to me.
6159.5 In reply to 6159.4
Hey Michael, okay I just turned off my anti virus and the software went back to running smoothly.
I tried several different tests and they all had the same effect on sluggish redraw when antivirus on and fast smooth
redraw when anti virus is off.
I have updated the application and still no improvement.
I use zonelabs security suite. I wonder how to fix this?
any thoughts?
thanks
6159.6 In reply to 6159.5
Hi Mike,
Well personally I would just ditch any anti-virus software that had such a continuous negative system performance effect.
But often times software like that will have some settings in it that will stop it from interfering with certain specific programs, so you can kind of turn it off in a more fine tuned way rather than just all on or all off. Look for some settings like that and add MoI.exe to any list of programs to not interfere with.
6159.7 In reply to 6159.6
Hi Mike,
Also add 'moi_commandprocessor.exe' to your exeption list, I found that out when Kaspersky was constantly monitoring it and did the same thing you're explaining, once the license was up for renewing I went with Microsoft security essentials no issues ever since :)
6159.8 In reply to 6159.7
Thanks Danny I will give this a try. clean install of my anti virus did nothing...
6159.9 In reply to 6159.7
hey Danny, that didn't help with the problem.
after sometime with tech support at Zone Alarm I isolated the problem down to "terminal Services".
when I turn that service off the problem goes away.
so... now Im just trying to figure out if I can run my machine with out it.
Show messages: All  1-3  4-9
