Viewport navigability suggestion
All  1-3  4-8
6145.4 In reply to 6145.3
Hi Max,
> I would like the Down and Up arrow keys to move forward and backwards,
> and the Left and Right arrow keys to strafe left and right.
Try these:
KeyCommand
LeftArrowscript: moi.ui.mainWindow.viewpanel.getViewport('3D').pan( -0.2, 0.0, 0.0 );
RightArrowscript: moi.ui.mainWindow.viewpanel.getViewport('3D').pan( 0.2, 0.0, 0.0 );
UpArrowscript: moi.ui.mainWindow.viewpanel.getViewport('3D').pan( 0.0, 0.0, -0.5 );
DownArrow    script: moi.ui.mainWindow.viewpanel.getViewport('3D').pan( 0.0, 0.0, 0.5 );
6145.5 In reply to 6145.4
thank you!
6145.6
That is very very useful. Thank you.
Though, is it possible to make the movement in the 3d screen work in screen space orientation?
Moreover, are there keyboard commands for the 2d screens as well?
6145.7 In reply to 6145.6
Hi 3image,
Do you mean for rotation? You can make rotation work relative to the view orientation by setting the option under Options > View > Rotate/Pan/Zoom options > "Rotation style" dropdown (at the top). Set Rotation style = "Free rotation" to use a view-relative rotation style, where left/right/up/down means left/right/up/down in viewing screen directions.
For panning, you can make keyboard shortcuts that work on the active view (the view the mouse is over in split mode or the zoomed viewport in single view mode) by using the following:
KeyCommand
LeftArrowscript: moi.ui.getActiveViewport().pan( -0.2, 0.0, 0.0 );
RightArrowscript: moi.ui.getActiveViewport().pan( 0.2, 0.0, 0.0 );
UpArrowscript: moi.ui.getActiveViewport().pan( 0.0, 0.2, 0.0 );
DownArrow    script: moi.ui.getActiveViewport().pan( 0.0, -0.2, 0.0 );
6145.8 In reply to 6145.7
Excellent!
Thank you again, Michael.
Show messages: All  1-3  4-8
