Patch
All  1-2  3
6143.3 In reply to 6143.1
Hi Ricardo, so possibly something like extend things by the the red areas here, then you build a sweep or network through that now 4sided region and then cut it at the blue line using Trim to produce your 5 sided final shape:
There is a lot of variation in your different curves here though, you will probably need to draw in several more cross sections to be used for the sweep or network to control the shape more, it will likely misbehave and tend to fold back over itself if you try to just directly use such different shaped ends as the only things being used to created the surface.
Ideally you'd try to have an even larger and more regular shape and trim away even more of it than just that little extended area, it's easier to create a better quality surface the more regular the outline is, big differences in shapes between opposite ends and lots of swooping around in tight spots does not make for good quality surface construction...
Show messages: All  1-2  3
