Field of view .ini
All  1  2-6
6136.2 In reply to 6136.1
i think, you don't need the .ini..
6136.3 In reply to 6136.2
Yes I know there's a option in the UI for that but it always reset back to 26° when I open a new document so I always have to change it back to 45° :/
I'm trying to change the default value at launch.
shapenoid.com stojan-voumard.com
6136.4 In reply to 6136.3
Hi DesuDeus, you can change how the startup views are set up by creating a 3DM file and then setting that as the startup template under Options > General > Template file.
Then when MoI starts up or when you use File > New, various things like the views and styles list will get read in from that template file.
6136.5 In reply to 6136.3
ah i see..well, just save out a file with your desired field of view and load it as a template..
uups..i have been "michael-ed"
6136.6 In reply to 6136.4
Oh thank you Michael I forgot about that possibility :)
I will try with a 3DM located on our server so that it's updated across my two workstations !
Show messages: All  1  2-6
