Protector Palm Pistol
All  1-3  4-8
6126.4
Great job.
6126.5
6126.6
How is it possible to get the 3D Isolines(Splines) from Moi to Cinema4d, someone an idea?
6126.7 In reply to 6126.6
Hi Zarkow,
You might try using DXF format, with the option set at export time to make polylines. I'm not sure but C4D may be able to import that.
Another option that might work is this plug-in: http://www.rhino.io/ - that adds 3DM file import into Cinema4D. It doesn't work for bringing in solids and surfaces from MoI since it only reads render mesh data for those kinds of objects, but it says that it also supports splines so it might work for that.
6126.8
Now I know, Cinema4D can Import IGES by Default, I have never try this before. Now I can Render the Isolines with the Sketch and Toon RenderEngine :-)
https://n5gusa.dm1.livefilestore.com/y2mvd5ER_6BUGeg_Fc7ETmj-mKvhgNnkatgQchLz0UL8xlPTNz-ldQpPvO-un02ZloOLhlSI5obEZPc3z7KxzQ9Ij823HYtM4K4QKI9xPDo-8E/HP5.jpg?psid=1
Show messages: All  1-3  4-8
