Viewport navigation: Rotate around selection
All  1  2-6
6124.2 In reply to 6124.1
hoi heiner..
option is already available..
http://moi3d.com/2.0/docs/moi_command_reference5.htm#View
http://moi3d.com/2.0/docs/moi_command_reference9.htm#Viewport%20controls
either you use the RESET button at the bottom of the window, so called Viewport controls
quote:
Fills the view with either the selected objects or all objects.
On the first click Reset will target just the selected objects and adjust the view so the selected objects fill up the viewport.
If you click the button a second time, Reset will target all objects in the model regardless of selection, zooming to fit everything within the view.
Reset also places the pivot point for rotating the 3D view at the center of what it zoomed to.
If you right-click on the Reset button, the reset will be applied to all viewports.
If there are no objects visible, Reset will restore the view to the initial startup default view.
or assign the command to a shortcut.
script:moi.view.resetAll();
..as this is very(very) basic stuff, you should definitely have a read through the manual or a look at the tutorials section
http://moi3d.com/2.0/docs/moi_introduction.htm
http://moi3d.com/2.0/docs/moi_command_reference.htm
http://moi3d.com/resources#Tutorials
~ marco
6124.3 In reply to 6124.2
Thank you so much,
belive me, I was looking for it, but I was looking the wrong way:
I was searching for "rotate around selection". I am sorry for that,
but i handle 3 applications at the moment (Blender, CINEMA 4D and Moi)
and that leads sometimes to confusion like that.
Again sorry, and a big thank you for taking the time and helping me out!
Best regards
Heiner
6124.4 In reply to 6124.3
hi heiner..
no need to apologize..lol..the pivot center thingy is indeed somewhat "hidden" in the RESET command.
ciao,
marco
6124.5 In reply to 6124.4
Good day all,
A while ago, Michael was very helpful to divide "Reset" into two separate scripts for hotkey assignments: 1. View or zoom all, and 2. view or zoom selected.
1. script:/* Zoom extents all */ var vp = moi.ui.getActiveViewport(); vp.zoom( 0.9 ); vp.reset(); vp.reset();
2. script:/* Zoom extents selected */ var vp = moi.ui.getActiveViewport(); vp.zoom( 0.9 ); vp.reset();
I find this very useful.
Rich
6124.6 In reply to 6124.5
This one is cool too
It zoom on selection or on everything if nothing is selected :)
No need to have two separate shortcuts
script:moi.ui.getActiveViewport().reset();
shapenoid.com stojan-voumard.com
Show messages: All  1  2-6
