Another vote for a 64-bit version
All  1  2-4
6121.2 In reply to 6121.1
Hi Al, unfortunately there's a considerable amount of work involved in producing a 64-bit version so it's not likely to happen anytime soon.
In the meantime there are some settings you can adjust to reduce memory consumption on heavy files, see this previous post for some details:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5322.2
If you adjust the display settings as mentioned there ("Mesh angle" with a rougher value like 25 degrees and uncheck "Add detail to inflections"), that will make a coarser display mesh and use less memory for the loaded file. The default display settings are more tuned for a high quality display but that also makes for excess memory consumption when high detailed models are involved.
6121.3
As workaround just export chunks of the model, rather all of it at once.
I'm sure in time 64 bit MoI will come.
~Kevin~
6121.4 In reply to 6121.1
Actually I was able to generate an OBJ file with an even finer mesh than the default by saving memory and running MoI in batch mode, i.e. executing it from a Command Prompt window with the following script as an argument:
var FileName = 'biggie.3dm';
var gd = moi.geometryDatabase;
moi.settings.igesJoinOnImport = false;
gd.open( FileName, true );
OBJFileName = FileName.substr( 0, FileName.lastIndexOf('.') +1 ) + 'obj';
gd.saveAs( OBJFileName, 'NoUI=true;Output=quads;Angle=10' );
gd.fileNew( true );
moi.exit( true );
Al
Show messages: All  1  2-4
