Edit size values using mouse wheel ?
All  1-3  4-7
6119.4
Using the mousewheel can be very useful,
The ringcircle2 script that I have, used to scroll down through the available values within the dropdown with the mousewheel , as well as using the drag down on the side.
This does not work in the last 3 ver3 beta updates for some reason
cheers
shayne
6119.5 In reply to 6119.4
Hi shayno,
Yes, I can confirm your issue within the latest Beta & the RingCircle2.
Also found the same problem happening with the drop down list for fonts when using Text.
HTH, Colin
6119.6 In reply to 6119.5
Dropdowns not responding to mouse wheel has been the case for all of v3 I think - it's a side effect from the big UI change from IE to WebKit.
Instead of the mousewheel once you have focus on a dropdown control you can use the up and down arrow keys though.
6119.7
I also found the mouse wheel useful on the fonts list as its quite cumbersome to use the drop down slider , then click each time to display the next one.
I just found that once the first font is clicked on and entered the up down arrows updates the screen with the next one , so I'm happy .
shayne
Show messages: All  1-3  4-7
