Script Error
6103.1
Hi I am trying to use "AssignPresetName" script with current MOI Beta 3. MOI stops working when I use this script. I have modified the path in the "AssignPresetNameDialog.htm" to the default moi installation directory. Does this script works with MOI Version Beta 3?
-sharif
Size: 33.2 KB, Downloaded: 24 times, Dimensions: 491x420px
6103.2 In reply to 6103.1
Hi Sharif, that version does not work with v3 because it uses a JScript.dll specific mechanism in it (the new ActiveXObject part).
I thin the newest one is this version here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.59
In that version edit line number 58 in the .htm file to have the full path to the PresetNames.txt file, so it looks like this:
var filename = 'c:\\Program Files (x86)\\MoI 3.0 beta Aug-1-2013\\commands\\PresetNames.txt';
Then that should work I think.
6103.3 In reply to 6103.2
Thank you! it is working
