Hi Rich, yeah sorry I still haven't quite got around to gathering up the notes yet, they will be coming soon.
Quick big ticket items:
Update to blend to select more than one edge on each side of the blend and also loft starting and/or ending in a point object should work too.
Some other new things are PDF format export now (2D curve export, not 3D PDF), layers and style colors written now to AI format, copy/paste should be working to and from Illustrator, Edit > Add pt can add points to surfaces now if you have a surface selected before you run it.
