LOFT SCAN
6095.1
Hay people.
Want to show you my new LOFT method LOFT SCAN. It is some kind of NURBS retopology.
It allows to recreate objects. And make them more simple, only one surface and one seam. I used it for example to recreate this seat that I downloaded from grabcad.com
I wanted to recreate it because I don't like this amount of edges it has. I wanted to keep my model to have as few amount of edges as possible.
Different objects need a bit different tweaks but this is main workflow:
EDITED: 6 Aug 2013 by ANDREI SAMARDAC
6095.2 In reply to 6095.1
M-Dynamics,
I also used this method to smooth your joystick)
It was a bit complicated, it takes me about 30 min to understand how to rebuilt it, because of your seams. But when I get it I rebuilt it very fast.
Image Hosted by ImageShack.us
6095.3
Interesting, could it be possible to rebuild surfaces with a script, or a rebuild surfaces button.
6095.4
Yes..smooth well the edges
Bravo !
6095.5 In reply to 6095.2
Things can get tricky with this technique if the shape has branches or holes in it, that's what makes a generalized "rebuild by sampled parallel cross sections" mechanism difficult.
6095.6 In reply to 6095.5
Michael Gibson,
Yep, there is a lot of different forms, that need diffrent aproach to rebuild, so making of a one universal script is very hard task I think .
Portfolio: www.samardac.tumblr.com
6095.7
Here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6101.1
I show one of ways how to handle holes with LOFT SCAN. Also how to treat corner points with LOFT SCAN. And how to smooth CAD models.
6095.8
Is the "loftwithsamestyle"-script available for sharing?
tx for the great technics!
6095.9 In reply to 6095.8
Jay, yes its availible but Im away for couple of days... When I'll be back I'll share it.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6095.10 In reply to 6095.8
Jay:
script: /* Expand selection over same styles and loft */ var objects = moi.geometryDatabase.getObjects().getCurves(), points = moi.geometryDatabase.getObjects().getPoints(), styles = new Array(); for (var i = 0; i < points.length; i++) { objects.addObject(points.item(i))} for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }; moi.command.execCommand( 'loft' );
6095.11
Hey Andrei,
thank you very much! You are the best!
Great that it is automatically lofting the curves in the right order!
Tricky one!
Very practical!
French version ;)
http://moiscript.weebly.com/tension-automatique.html
EDITED: 16 Dec 2014 by PILOU
