Bug Diff?
All  1-6  7-9
609.7 In reply to 609.5
Hi Pilou, your example #3 was a bit easier to examine since there are not quite so many pieces.
But this is also another case that will be difficult to fix up soon. It is a bug in the processing of 2 surfaces that touch each other like this:
In some circumstances like this where 2 surfaces just exactly touch each other at a point, the geometry library gets confused about which resulting piece is supposed to be kept and which is supposed to be discarded. I've seen this one a couple of times. It's another one that I hope will be solved by an update to the geometry library in a future version after V1.
It's another example of problems involving different pieces just barely overlapping or touching each other.
609.8 In reply to 609.6
yes it's odd bug :)
But seems there is in general another solution for have the same result by a another way :)
On another subject: about http://moi3d.com/forum/index.php?webtag=MOI&msg=582.17
> Fillets block on construction line!
Yes, this is a limitation of the current fillet engine. Fillets won't cross an edge boundary like this. I hope that this will be improved in future versions of the geometry library that I am using
Does any chance you find new fillet library for the V1?
EDITED: 14 May 2007 by PILOU
609.9 In reply to 609.8
Not the complete new library, but there is still something left for me to try. There is a different interface to the same library that seems like it tries a couple of different approaches if there has been a problem with the standard method.
It is possible this may help out a bit on some thing that cause problems, but I'm not quite sure how much of a difference it will make yet.
Show messages: All  1-6  7-9
