The new blend
All  1-13  14-17
6085.14 In reply to 6085.13
Here is one small example:
I have a lofted area that is blended into a trimmed shape.
Where ever the control points are placed, the resultant surface pretty much does what you want in that approximate area, but sometimes has to negotiate tight bends and often forms kinks.
Here's Blend...
Here is an "artist's rendition" of added Blend synchronization controls, (or "shapes" as Rhino calls them.)
Here's Blend on drugs. (the prescribed kind) ;-)
I know this would probably work, because my usual method involves Trimming the edge curves to form smaller blend panels, which have to sometimes be "scallop blended" between each other.
Speaking of the Trim command; it has a button to [Add Trim Points] and then gives you a picker... perhaps adding control points to Blend could be done in like fashion.
Here's an example to show the 'not so clean' Blend result:
http://k4icy.com/Moi3D_Tutorials/blend_control_ex.3dm
Yes, the edges are wiggly and the G2 Blend was probably too sharp, plus the to and from shapes have a great deal of difference between them with one being sharper... but I think this ability would help, as they say, help "keep a tight formation."
Thanks for including that one on your laundry list... Honest - I'll promise to feed it, water it and take good care of it. ;-)
And again, thanks for the new feature, I've been playing with it all day. In fact, I keep catching myself wanting to "Merge" and "AddTrimPoints" to edges.
This one ALSO will blend from touching edge curves on surface elements that are not even Joined! AWESOME!
Oh... and would it be beneficial to add independent Bulge control to each sync pair?
EDITED: 4 Aug 2013 by MAJIKMIKE
6085.15 In reply to 6085.14
Hi Mike, thanks for the example file, that's a good case for me to test with.
There's another thing that can help with bunching up blends like that possibly even more than adding "sync points" which is what I called "Planar sections" in Rhino. That's an option that changes how the blend cross sections are formed. In the default mode each blend cross section tries to come off perpendicular to the curve tangent of each edge curve. When the edge are kind of wiggly it makes the sections kind of writhe around and that creates lumpy shapes.
Planar sections makes each blend cross section to be in one single plane, it's sort of like what is called a "pencil of planes" which is like a bunch of planes rotating around one single direction, so you have to pick a sort of "up" direction that's used to orient the family of planes that are used.
That then makes each blend section to be sort of more orderly and not jiggle around as much when there are little wiggles in the edge curves.
You'll probably need that option as well in order to make this particular blend example behave very well.
6085.16 In reply to 6085.14
Hi Mike, also:
Yup, this update should really help cut down on needing to do those extra "prepare to blend" steps!
That could certainly be useful but it would involve a quite substantial increase in the amount of work involved to implement it... So probably farther off in the future than just having sync points to start with.
6085.17 In reply to 6085.16
Thanks for the insight, Michael!
"Planar Sections" to force a more orderly Blend result... that would be interesting.
Show messages: All  1-13  14-17
