Hi Mike,
> Oh man! Someone send me a clue next time... I miss the new Beta by two day! ;-)
It's still hot off the presses! I haven't even gotten to the official announcement quite yet.
> What is "Make Corner Point"?
"Make Corner Point" is only supposed to show up when you're adding points to a curve. When that's enabled when inserting a point on a curve if you then move that point around it will make a sharp corner in the curve.
> Hmmm, Michael, I hope a "Subtract Point" is possible someday...
Certainly someday, one problem is where to put it. For surface add point I was able to extend the already existing curve add point command which is always a major plus because it prevents UI bloat.
